1 - 20 of 40 Posts
Midway through my audio install.
Now "Service Keyless System" comes on every time I turn on my vehicle.
The remote turn on with my FOB works, but the keyless entry-and-go does not (when I touch the inside of the handle, nothing happens).
Did I reset the system because I disconnected the battery? Any way to reset it back without having to go to the dealer? Is it possible I might have damaged or left disconnected (doubt it) some keyless device in the driver's side door when installing my speakers?
Any help or guidance would be appreciated!
Greetings,
Congratulations and welcome to the FOB key club. By know means you are the first one to experience this problem. I consider this one the worst parts of the JGC.
I usually do is to shut everything in the JGC, leave and lock it with the remote and then open it with remote. This might take a 2 or 3 times to work. If it does not and you are under warranty, bring to the service dealer to have the system re-flashed. I have had the unit replaced and re-flashed 2x now.
Best for now. :)
Solved!
After reading through past posts, figured out that the problem was in the rear sensor. Had left it disconnected during my audio install!
A quick plug-in and everything is back to normal.
Thanks!
Can someone please help? I am having the same problem with my 2015 Jeep Grand Cherokee. Installed aftermarket audio and then the next day my door handle keyless entry-n-go won't work at all... I put my hand on the handle and nothing. I try to lock the door from handle and nothing.
My remote start, unlock and lock, trunk open close all works from the key itself. But for some reason the keyless entry does not want to work.
CAR HAS LESS THEN 1000 miles. And i have tried both key fobs, still nothing.
Someone please help so i don't have to waste time and take car into dealership!
New to this site so i hope i wrote the question correctly.
Someone said rear sensor could be disconnected. But what is the rear sensor and where is it located?
Thanks for your Help,
Danny
look carefully in all the places that were opened up during the stereo install.. most likely some connector somewhere was knocked off..
Open boot. Remove floor. Remove 2x tubs. Release 4x screws on tie downs. Lift off lower tailgate threshold garnish. Lift up the large spare wheel surround. Plug in module on rearmost edge.
Cheers,
Steve
What he said. There is a sensor that in under the rear trim piece. Same thing happened to me when I did an install in my '11 GC, plugged it back in and everything was back to normal.
Cant find that module you guys are talking about...
Removed cargo mat. removed 2 trays, tire, and tire foam plate. then removed the outmost plastic mount for spare tire holder. there is no module or anything like that anywhere near the spare tire holder....
The cargo tire hold compartment is completely emptied no module or anything of that nature
Am i missing anything?
Could it be an update from jeep?
Thanks for your help!
JGC Overland
The module should be clipped onto the big "circle" of plastic. The wiring is tied to the metalwork just under the door catch. I'll see if I have a photo...
Limited 4x4
Thanks all for this post. New member here and was running into the "Service Keyless System" issue. I read through the posts on this thread, went into the garage, and fixed it!
One quick note for any further readers - for 2014 Grand Cherokees, the module to plug into is attached to the plastic threshold for the spare wheel well, but can only be accessed by lifting the rear trim piece that has the two rear ties downs. You do not have to fully remove the rear trim piece, but you do need to lift it out of its clamps. There were some references to its location on previous posts, but I wanted to provide a little more color.
Thanks again!
Thanks all for this. New WK2, passive entry has never worked. Could be that they disconnected when installing the tow bar. salesmen didn't know, the service department said that the earliest they could investigate is in a months time!
Using your advice I found the disconnected plug and it's all working - about 5 minutes work once I found a 7mm socket to remove the two tie-down's.
Thanks again.
Overland
Guys I need your help! I followed the instructions and managed to remove the plastic cover for the spare tire, but I couldn't find any module attached to it. I did found two sockets one grey and one red and black. If any one could post a pic of how the module looks like it will be highly appreciated!! Thanks
1 - 20 of 40 Posts
