1 - 20 of 61 Posts
GC Ltd. 4x4
Can anyone tell me when the SPORT mode is used in my 2013 JGC Ltd. 3.6 4x4, does NOT have the quadra lift suspension. I see when I set it on SPORT the ESC goes off and the engine jumps up a few hundred rpm's. That seems to be the only thing I've noticed. Any explanation would be appreciated. Thanks Guys.
Banned
LAREDO
The Sport mode keeps the transmission in gear longer and provides better throttle response. The Grand Cherokee in its Normal mode is tuned more for a comfortable ride than for athletic moves. But Sport mode is now available across the lineup, engaged with a pull on the transmission handle. In Grand Cherokees equipped with the air suspension, Sport mode wakes up the truck and transforms it significantly, changing shift patterns, suspension settings and ride height to minimize body roll and create a more surefooted performance in fast twisties. In models without the air suspension, only the transmission behavior and throttle response change.
So it should be used when you want to partake in some more spirited driving.
It also changes the power distribution to reflect that of a more rwd rather then 4wd.
Does anyone ride around in "normal" mode, ie non eco non sport?? I think its overlooked that we have 3 modes actually not just eco sport.
Pushing the eco button to turn it off doesn't automatically trigger the sport mode!!
:mindblown:
:mindblown:
I always drive mine in "normal" mode. Sometimes I will use sport mode for merging or the like. I hardly drive in eco mode as the throttle response can be scary slow.
2012 Jeep GC Limited
I use Sport mode in the twisties. It holds the gears longer since I hate it when it upshifts when in normal mode and I have to push the pedal harder so it will downshift to a lower gear. Other than this, I have no use for it.
I use sport mode while city driving and dry condition highways to improve my driving experience, in my opinion it improves throttle response considerably but leaves holes in the handling which I assume is a result of the ESC being shut off. Not good for wet conditions.
2014 JGC Limited 2wd
I just used it for the first time the other day and was quite pleased.
I bet it is different experience in the V8. On the V6, I found no difference other than holding gears longer. Throttle response was the same...
On my Cayenne S, the sport button changes the car completely.
cheers,
-S
I wish that once sport mode changes the suspension to aero, that it would stay in aero if I change back to ECO. This assumes that conditions are such that aero still makes sense. Currently, if I use sport mode to get a quicker start or traffic merge, it switches back to normal ride height no matter what. This is more wear and tear than is necessary.
Mine will stay in aero mode providing im doing 50mph or more or whatever....
3+ year old thread... ;)
Don't see why not but you'll give up some mileage.
Is it okay to drive around in Sport Mode all the time (instead of Drive)?
No problem at all...as long as you don't mind "pushing the button" each time you start the vehicle. ;)
2014 Summit
In addition to there being three modes, I always take off Traction Control also. I don't need some faceless robot telling me more than it needs to!
1 - 20 of 61 Posts
