1 - 12 of 12 Posts
2014 Grand Cherokee
When I push the button to put it in sport mode the light for ECO mode also comes on.
Is that correct?
2019 Trailhawk 3.6
On the earlier models, the opposite occurs as the light indicates the ECO mode is on unlike the lights for collision avoidance which indicate that it is off. Maybe there was a change in the 2019.
2014 Grand Cherokee
My 17 when I hit the Sport button the ECO Off light comes on, and of course I hit the Auto off also.
So the ECO is turned off when in Sport mode.
The 14 ECO light indicates that it's in ECO mode. Interesting.
MY '16 here. If the ECO light is ON, then ECO is turned OFF.
In other words, ECO is ON by default. You have to deliberately disable it by pushing the button.
...or when you enable Sport mode by pushing the button, then it automatically disengages ECO, hence both buttons are lit.
Discussion Starter #8
So when the ECO light is on, it's off.........When the sport mode light is on, it's on. And when they are both on, one's on and one's off.....
It comes down to the label on the button...If your button is labeled ECO OFF (which yours is), then hitting that button turns ECO off...pretty simple.
On the older models, the button was just labeled ECO, which meant hitting the button (causing the light to turn on) would turn ECO on.
Zoom and see that the button says “eco off”. So when eco light is on the Eco Off mode is engaged.
I agree that this can be confusing but it’s operating correctly.
light should be labeled same as button - ECO OFF.
1 - 12 of 12 Posts
