1 - 10 of 10 Posts
2000 wj jeep limited
i acquired a set of nice oem 08 srt-8 jeep 20" with 275/40/20 on fronts and 315/35/20 on the rears. the rears are really wide and i had to trim the coil bucks on the frame and push the shock mounts on the axle in toward the center about a 1". With the power ill be making i'll need the extra rubber. it looks really sick and i've never seen another wj with this tire combo.
07 grand cherokee
sick!
is that a conn. plate? you should come to the new england meet in may with that thing!
Yea once i start my new motor and get it broken in and tuned my ryan in the next month or two, i will def. be up for that. just let me know where and when. thanks for the heads up.
07 grand cherokee
SRT8 Superbee 2013
Is that a 4x4 as I have always been under the impression that if you have a 4x4 all 4 tires need to be the same size or you could blow the transfer case/ transmission? If you use the 4WD option.... Especially with all the juice a SRT8 is pushing, would hate to see something get damaged.
I mean staggered as larger width wheels in rear. They are the same size in height so that is the only thing that matters with my 4wd. 275/40/20 in front and 315/35/20 in rear. my bro ran these on his srt for years so there will be no problem.
i did 2.5" from there into high flow precats to a x pipe all wrapped. from there i did 3" after the x pipe to flowmaster single chambers race mufflers. on the drivers side i went under the tc tail housing and then straight back. i had to cut the front gas tank skid plate where it mounts on the frame to get the 3" pipe through. i have swivel ball connections in two places so everything can come apart. it sounds nasty! i do have clayton long arms so routing is alittle easier. i had this done with the stock a arm and it still worked nicely. 3" pipe in rear to 5" tips.
1 - 10 of 10 Posts
