Has anyone swapped the Laredo wheel with an Overland ( wood ) wheel. Only difference is the Laredo doesnt have the adaptive cruise control.
No paddle shifters to mess with or anything.
Any input? Thanks!
Can you specify what year range you are asking about?
If the 2014 and up steering wheels are like the 2011 - 2013 steering wheels then you can
swap the bezel from your current laredo steering wheel with the wood rimmed donor. Then you would just tuck away the y unused heater connections.
Its a 2012 wheel going into 2102 truck. . When you say bezel what do you mean? The whole wheel doesnt have to be switched?
14 WK2 Laredo E
I had a 2012 overland wheel put into my 2013 laredo. It bolts right up but you may need to swap over the buttons and trim if they don't line up.
Grand cherokee
I have a 2011 limited GC that came with a black wheel, so I swapped it with the wood one, I just swapped the wheel not the center console where the airbag is, if u have heat option u can connect it eazy, but the wood heat won't work because requires a different connections that only comes withy the overland and summit, btw I let my dealership do the swap, don't wanna mess with the warranty
