1 - 7 of 7 Posts
Hey All,
I am going just about insane at this point, I am hearing a strange clicking from what seems like the rear shocks (though I don't have a clue if that is actually where). I got the Jeep at 81000 miles and have since put 10k on it. After about 3000 miles I put on a RRO lift. After about 9k miles, I put on new rims. This is when the clicking seemed to start (if I remember correctly).
Any idea what the clicking sound could be?
Thanks in advance,
Could be a number of things. Sway bar links, bushings, lca bushings, uca bushings, ect...
Best thing to do is get under there and visualy inspect parts. Check for witness marks. I had LCA bushings in the rear torn...
2005 Jeep Grand Cherokee
do these wheels have loose center caps or hub covers? Are the wheels or tires rubbing on anything?
Nope, neither of those are the case. I am taking it to the stealership tonight to get it taken care of hopefully. I will let you guys know what is found.
I had this same issue not long ago and it ended up being my parking brake pad had completely come off and was just rattling around in there at low speeds and it sounded like a clicking noise.
1 - 7 of 7 Posts
