my system will be less than 1000watts, but I guess my main concern is that if I am changing out the way that the current connections attach to the battery, might as well just upgrade the wiring. If I'm to keep the existing wiring in place...I'm not sure how I will do this all then.
Yeah, I'm at about 1,000 watts as well and I have no electrical issues. I still want to do it, I'm just am lazy, hehe. But it can only help and it's cheap as hell to do. Plus, it will look all pretty under the hood with that techflex and whatnot.
Hey Matt,
I bought my Distro block today, and my wiring yesterday. Next weds I will be buying the deadening materials.
My list is down to:
RCA's 15' - 17' for 2 amps
Techflex and Shrink
MDF for the false floor and Box
New mounting hardware for the 9887, and radio adapter
I think that's it. though I'm sure there's more.
Very nice Andy!
Make sure to figure out how much techflex and heat shrink you want... then multiply it by two!!!! Seriously, I think I used twice as much as I originally calculated. It's very cheap (use "furryletters" from eBay for the expandable sleeving! - very cool dude) and you'll want more down the road. Also get zip ties, you'll use a shit load of them. Labels and clear heat shrink (if you plan to label). Any baffle material you'll need + hardware.
since you are going to be running active (and most likely going to swap out drivers down the road) I'd suggest doing what I did and making speaker wire harnesses that run from the amp to the front footwells. This is good for two reasons; as pointed out, if you are switching out drivers and maybe changing locations, it's good to be able to make short runs from the driver location to the end of the terminal in the footwell. Also if you decinde to change the location of the amplifier, you won't need to re-run wire or solder onto the existing run.
Labeled speaker wire harnesses
Labeled wiring for terminal block >> front drivers
Labeled wiring for terminal block >> amplifier
Expandable sleeving + heat shrink + zip ties FTMFW!!!
Before..
After...
LOL
