1 - 12 of 12 Posts
Has anyone installed Thule 460Rs w/ Aeroblades yet? I installed mine a few weeks ago and have recently started hearing a high-pitched squeal/whistle at speeds of 55-60+. It's not very loud, but noticeable nonetheless.
I thought it was something else because the noise seemed pretty localized to the area in front of the passenger seat, so I had my dealership check it out when I took it in for oil change. They also thought it was something other than the roofrack, but when they removed the roofrack, they said the noise went away (so... assuming they were being truthful, it seems to be the roofrack).
Has anyone else experienced this? Any ideas on getting rid of this mildly-annoying whistle?
Do you speak of the rapid Aero bar or the new aero blade? ARB47 or RB47?
Have you tried to remove the roof rack and verify for yourself? Its 8 screws if im not mistaken.
I posted this same question but questioning the new aeroblades because I am trying to upgrade from the aero bars to the aeroblade. The aero bars do whistle for me at speeds that you mention with no flairing.
This
or this??
Yup! There is wind noise from my Aero Bars. The noise is no big deal, but sometimes, if the wind is right (or wrong) it can get loud.
Not enought noise to remove them when I don't have the Thule box on.
I have the Aeroblades... the second of your photos. And, no, I haven't removed yet to verify for myself. I will eventually... and will post if the noise is present without. I tend to doubt it, though... since I never heard that noise until I added the bars.
I currently have almost 23,000 miles.
Good to know. If you have time you should try removing them. I want to upgrade to aeroblades but would hate to have the same effect. However I bet the whistling you hear is probably lower then the aero bars I have. As others state it's not super bad but on highway trips it's there the whole time.
I have the blades
I also hear the whistle occassionaly
Didn't hear the sound before so I don't think it's the jeep
Nothing terribly annoying, but i haven't taken her on a long road trip since installing them
We will see
Do you hAve one of their cargo box's? Mounting them to the blades is a bit interesting ...I assume a improvement is on the way...but it works
I just upgraded from the aerobars to the aeroblades and I'm getting a high pitched whistle as well. Tried adjusting a few different ways. Bar spaced as far as they will go, bars space ~28" starting at front most position and same starting from rear most position. Tried with and without the cut to fit strips are in the bottom. Nothing seems to cure it. Its almost MORE annoying than the aero bars because although they were louder, they weren't nearly as high pitched.
Jeep Grand Cherokee
As an interim measure, try wrapping a length of elastic cord or string two or three times around the bar along its length. That will break up any vortices emanating from the bars. However, the whistle may be coming from the fittings.
I have the Aeroblades and no sound of any kind. Make sure you cut the under the bar ends trim to the exact lenght and make sure your rubber insert on top of the bar is well set and makes sure you close the bottom ruler trim cover fully.
Do any of you guys have that wind deflector thing that goes in front of the bars? I get a bit a noise from my aero bars at highway speeds and am way too lazy to take them off.
The wind fairing for the new aeroblades (pic #2) will not fit. According to Thule, they believe the shape of the new bars should've eliminated the need for the fairing. The fairing is reserved for the square bars and now discontinued aerobars.
I bought everything in one shot from EMS during their 20% off sale and discovered this first hand as i was attempting to install the fairing. It had to be returned and i put that money toward the yakima fatcat6 snowboard carrier. Wind noise is not too distracting especially since the only thing I really hear is my noise maker intake.
2014 Limited Hemi 4X
So can’t see your pictures but have what I believe are the blades, [the bars go inside the 90 degree end fitting/mount/caps. Great looking, STRONG & SOLID - BUT - with my sunroof in the vent position, [smaller sunroof], the whistle is almost completely unbearable - it is seriously loud. Every there position is fine. And yes, they are mounted correctly with the textured strips in place, and there are no open spaces on the bars to “plug”.
A fairing will have to be customized to work as the front bar is SO close to the trailing edge of the sunroof that it wont fit without cutting it down, plus other complicated things - which, I am very close to doing. I have the bars spread to the extends the to haul 14’ paddle boards and NEED all I can get. Plus, I seem to recall that the heavy duty bolt on option had limited placement options……..not in a hurry to spend hours taking it apart only to find out I was correct about that part.………..clearly it’s a venturi effect between the two - like putting your lips close enough together to make a whistle……..but this just shouldn’t be the case. I wanna live in a perfect world ;-]
Anyone else have this and or found a real remedy???
1 - 12 of 12 Posts
