I have a couple week old JGC Limited X and in the last day a thumping sound has developed from the rear driver side area. There’s nothing inside or in the spare area thats moving. I took a look under the car, especially around the wheel well area and didn’t see anything obvious. i know sounds can be deceitful to track down but am curious if anyone else here has found something that would cause this.
also there is this tube that is hanging down the side skirt that might be the culprit. Is this a fuel overflow tube? And does it look out of place?
Lug nuts are good. I drove around with it a bit more and it sounds like something is maybe dangling and slapping against the vehicle. The sounds happens when going over bumps and you'll hear a couple of residual thumps after the bump has passed. I checked again and didnt see anything obvious. Closest dealer is telling me they are booked two weeks out (really loathe that place).
I have a 2014 Grand Cherokee Overland that is telling me "Service Four Wheel Drive System" every time I start it. The traction control light then turns on immediately afterward. I am also no longer able to use the cruise control because of the service four wheel drive message. I am currently at...
Hello,
Anyone know of any common issues on WK2 MY2011 with the heated seats?
They come on for about 10min and then shut down..
According to the manual, the first four minutes provide a boosted heat output. They are designed to stay on high for 45 minutes, then switch to the low setting for 55...
HI all! Hope everyone had a great Thanksgiving.
So I went to the gym this morning all was well, got out started up my rig and it starts making this ticking/clicking noise when I put it in gear? As I drive a bit, it stops. When I come to a stop at a light, starts ticking/clicking again for...
So I've seen some threads of similar issues and Jeep replacing the hood. I should still be within the 5 year paint warranty I've had a dealership near me take a look and saw the paint peeling at the front of the hood and even overspray this has been getting worse and worse lately. They told me...
I am having issues re-installing my passenger side blend door gears. The bottom gear on the actuator was broken, so I have a replacement part as shown below. But it looks like the top mating gear is not in the right position. That gear can only be installed in 1 position, as shown. That top...
