1 - 7 of 7 Posts
Hi,
í‘m wondering if I can put a 265/50/20 tire on 20x10 +45 Offset Spyder Monkey replica OE rims or if I need to go with 295/45/20.
Does anyone run a 265 setup on a 20x10 rim?
What are the pros and cons compared to 295 besides more tire options.
Looking for experiences and pics.
thanks
265 is the stock size so I would stick with that. 295 will be much wider and 45 will be a smaller aspect ratio and with everything combined I would imagine it's much louder on the road. Some handling characteristics would be changed as well and you may have some rubbing on the inside if your wheel backspacing is off.
Hm...but many have put 295/45/20 with 20x10 +50 offset on a standard Grand Cherokee WK2 without issues. It‘s the SRT configuration.
is 265 not too small for a 20x10 rim? I assume the width of the rim will stretch the 265 tire significantly. I like a wide look but I was thinking this is gonna too much for the 265 tire?!
SRT8
265/50/20's is a Stock size for every WK2 Jeep besides an SRT. You can do it but typically we do 265/50/20's on 20x9 rims for winter skinnier cheaper tires more options.
295/45/20 will fit your Stock Jeep just fine with OE replica's It's what ever you want it to look like I rock the 295/45/20 DWS06's
I run 265/50-20 Nokian snows on 20x9 et35 SRT wheels. Works just fine.
233294
For summer I have run 295/45-20 on 20x9 et 35 SRT and now Trackhawk replica wheels. I've run the 295/45 on 20x10 SRT Goliath wheels but wasn't necessary.
233295
I did try to mount my 265/50 on the 20x10 wheels and the wheel lips stuck out further than the tire sidewall so definitely not a fitment I'd recommend.
2020 WK2 Limited X
Nice looking ride man!
1 - 7 of 7 Posts
