2015 JGC Overland
My 2014 Overland has 265 50 R20 both front and rear. Does anybody know if that rim can support a 275 instead? I want wider tires on my Overland but not sure what the capabilities, clearances, etc for the 20 inch rim. Anybody know the widest tires you can put on instead of the stock tire size of 265? If you can speak to the 2011-2013 I'm sure they are roughly the same dimensions also. Thanks
A 275/55R20 will fit without any rubbing. I might be mistaken, but I think anything bigger than that will rub. Also, the speedometer will be off a little bit due to the slightly larger circumference of the tire.
