Hi all, first post here so please bear with me. I have a 2011 4x4 Overland, 5.7L HEMI, with the Trailer Tow Group IV package. I've been pulling a 23ft travel trailer weighing in at approximately 4,300lbs fully loaded, and I use a weight distribution hitch with sway control.
The GC pulls the trailer really well down the road, no lack of power on the climbs and sway is manageable. The only issue I'm having is high engine oil temps while monitoring the digital gauges. The rig has never overheated but the oil temp has reached between 250-260 degrees. In that instance the towing conditions were rather rough; 85+ degrees outside, highway speeds, and lots of hills. While the oil temp was high, the coolant temp seemed okay @ 220 and the transmission temp @ 210, both hot but not outside normal spec like the engine oil.
The Trailer Tow Group IV package includes "HD engine cooling" which from what I can tell adds; a larger cooling fan, high amp alternator, and engine oil cooler. Also I've physically confirmed the existence of the engine oil cooler. Lastly, I always use the tow/haul mode while towing.
Does anybody else with the 5.7L HEMI experience high engine oil temps while towing? Would an upgraded/larger engine oil cooler help curb this problem?
