1 - 8 of 8 Posts
GC Limited
The first link looks to be ones similar to the ones that came stock on our jeeps. The second link is more for the JK guys with moab wheels. They both have the right frequency. You could prob go with either. The first one's would give you more of a sleek look though, they wouldn't stick out as far. You might want to check out Rockauto.com I found my sensors on there for about 30 bucks a piece.
I found a set on ebay and rockauto, are dorman or other aftermarket replacements alright?
I found the answer after doing more research I think i will be ordering a set of 4 dorman sensors with the same frequency and saving $69! Thank you for your help
GC Limited
No problemo, the dorman's should work just fine. They are to the same basic specs as the OEM sensors. Just put them in and within 10 miles of driving they should sync up and show on your Evic display. Tell us how it works out for ya!
The sensors are brand new, I reset the electeical by taking the negative off and pumping the breaks...all sensors show the correct pressure...why is it still saying "service tire press. System"
1 - 8 of 8 Posts
