2013 Grand Cherokee
I don’t have the EVIC that shows which tire is throwing the sensor. Is there N actual reset button on the 13 JGC Laredo E and where the F is it…
235649
If it's like other Jeeps, you have to inflate the tires to 36+ to reset the light.
Reactions: cajunkid
High altitude
also is the tire light flashing then goes solid when the vehicle is turned on or is it just a solid tire light? if it is flashing it could be a sensor or module issue. if its solid you may have a tire losing air.
2013 Grand Cherokee
It flashes for a few seconds then goes solid
