1 - 11 of 11 Posts
I had my dealer install a hitch on my 2011. Yesterday hooked up the trailer for the first time and the stop and running lights work but not the signal lights on the trailer. Will take back to the dealer this coming week for repairs but does anyone know what the problem might be?
02, 06, 11, Jeeps
Check the TSBs there is one for turn signals inoperative. plastic on the connector is somewhere it should not be. I believe all they do is scrap it off the contacts so the signals will work.
Discussion Starter #5 (Edited)
Not sure what a TSB is. But am delighted with the help you all are offering!! Great board. What exactly is a TSB? (turn signal board?)
FYI: I do not have the electronic brakes so have only the 4 contacts with the center pin.
TSB = Technical Service Bulletin. Alerts from Chrysler corporate to their repair centers about common problems.
If you're using the 4 pin, then the turn and brake lights are controlled by the same wire -- Green for right side and yellow for left. So if both brake lights work but turn signals do not, it must be a problem with the Jeep wiring. Time to see the dealer.
02, 06, 11, Jeeps
To the OP was the TSB applicable? What was the result of your dealer visit?
02, 06, 11, Jeeps
Just trying to find the end result.
Discussion Starter #10
Final result: The dealer said that the computer has to be reprogramed for the trailer lights to work. For whatever reason, when they "dealer installed" the hitch, the computer didn't register the reprograming they did. He said they did it again when I took it in for the first 3,000 mile oil change and that it then tested okay. I have not hooked my trailer up yet to see for myself as I've been busy at work. :thumbsup:
2006 GCO
Trailer fuse was missing in mine. Put in fuse and all the lights came on the trailer. (under hood)
1 - 11 of 11 Posts
