Grand Cherokee Lmt.
My 99 Jeep 4.7 Grand Cherokee is showing codes - P0420 and P1195. These are defined as "cataylst sys. efficiency below threshold bank 1" and "oxygen sensor heater circuit is bad".
Anone have advice or info on correcting these issues?
The beast from Brazil
I found a different meaning for the last code: P1195 O2 Sensor 1/1 (Bank 1, Sensor 1) Slow During Catalyst Monitor .
This to me looks as a bad bank 1 upstream O2 sensor. It could make the fuel mixture lean and cause the loss in power.
Because the PCM looks at the sensors 1 and 2 for the monitoring of the cat, a bad number 1 sensor could make it think that the cat performance is bad.
Hello Guys, I have the same problem. There any Picture where this sensor are located? Thank You.
