I have 2011 CG 65K the UConnect system started acting up by not allowing access to the HDD...all else worked.. then it began starting at the Jeep U Connect screen, last radio station would play, unit would go black and no sound..for 15-20 seconds and restart...now the unit cycles between JeepU connect screen for 60 secs and the black for 15 repeat..I disconnected the negative battery cable for 30minutes...Same issue...on/off button has no effect..no sound, no back up camera etc....Any one have a hard reset solution..I have read some replys however they do not apply to this unit....Please help...
I can "hear" the Hard Drive clicking and tapping when it is on.. I am planning to try to update the Software using a Jump Drive, and I hope it will initialize and start... I hate to have to give up on this unit, I only have 66K on it so far Thanks for your response...
