1 - 20 of 285 Posts
Due to the remote exploit vulnerability I have upgraded to uConnect 15.26.1 on my 2014. However, in the two days it's been applied I have already had to restart the Jeep multiple times to regain functionality that used to work flawlessly.
For example: intermittently, climate control fan speed will not work (the fans stay off even though the screen indicates they are on level 1–7). Have to restart the Jeep to get the fans to work again. Also, the backup camera now intermittently displays no video and the path overlay jitters. Have to restart the Jeep to get the backup camera working again.
I imagine there are more intermittent loss of functionality issues I have yet to uncover. This is pathetic.
Does anyone have the service manual for a 2014/2015 who can tell me if there is a separate antenna for the cellular datalink? I want to disable the cellular datalink antenna (leaving FM/SXM radio and GPS reception intact) and then downgrade to the previous version of uConnect that worked fine.
As it stands, the current version of uConnect seems to have built-in simulated hacker interference in terms of having my Jeep randomly lose functionality. Maybe it's so I don't feel left out compared to all those unpatched Jeeps getting exploited by actual hackers.
I'd try a factory reset and see if that clears up the bugs.
Also you can reboot radio without restarting Jeep.
Also sprint has blocked the vulnerability without applying the update.
My MY15 seems fine with update, but it may be different. Except Nav seems to create some odd routes.
Discussion Starter #3 (Edited)
Protip. Thanks. It's still pathetic, though.
That's good. However, I am done with the datalink. I never wanted it in the first place. All it does is allow FCA to track my vehicle, and having an attack surface exposed like this is nothing but a liability. Obviously they didn't airgap the radio like they should have.
I'm willing to be first to experiment with a datalink antenna disconnect if someone has the service manual. How involved is it to get back there? Weekend project?
Wow that's really weird. My late built 2014 had a jittery backup camera image prior to install, and now it's perfect after the update. Very weird that yours actually went bad after the update, and mine was fixed.
No bugs for me, works great.
How does one get the update? Do they just push it to our Uconnect without consent?
If your VIN qualifies, they're supposed to be mailing the update on a USB to you to install.
You probably can download it yourself from the U-Connect site if you choose.
Or you can take it to the dealer and have them install it for you if you don't want to mess with it. They'll have it available before you get yours in the mail anyway.
Could you, instead, just stop paying Sprint, and Sprint will disconnect your Uconnect Access from their network?
No one pays Sprint directly for any portion of the Uconnect services - it's all through Chrysler. Even if you activate wifi on your Uconnect, you're paying Chrysler - then they pay the Sprint bill.
Banned
Try reinstalling the update from a fresh download of the file... Sounds like yours is corrupt and didn't fully install or update properly. No one else is having issues.
Discussion Starter #10 (Edited)
Don't get me wrong: the Dec 2013 though mid 2014 versions of the firmware had jittery backup camera video. The last version release before the current version finally fixed that problem.
*This* version (the latest) introduces a brand new, completely different intermittent problem. There is no video from the camera at all. The path overlay jumps around on top of the equivalent of a flickering TV tuned to a dead channel that displays nothing but flat dark grey.
After 2 weeks I'm still having zero issues with the update. If you're having problems, re-download and reinstall. In the past this has proven effective in solving problems with a new firmware upgrade.
Discussion Starter #12
Unfortunately, FCA doesn't publish a shasum for the image or anything. It seems to perform an internal checksum. I reapplied the update.
I still want to kill the datalink regardless of whether I elect to downgrade to the known good (albeit exploitable) previous firmware revision.
2015 Altitude
I chose to just pass on the update. my stuff worked fine. If someones gonna hack me, so be it (but not gonna happen). they released it very quick after the hack went viral. Im not interested in a quick fix from them. I knew it would be a buggy mess. Maybe in a few mos.....
Just had my dealer update mine. So far no problems. I would have attempted to do it myself, however, I figured I would let them be responsible if anything went buggy.
FCA supposedly first heard about the hack in October of 2014, so I don't think it was a quick fix.
Overland
Downloaded and installed mine a couple of days ago, no issues. I'd reinstall if I were you.
Discussion Starter #18
Heh. Well, at least we have a known good firmware revision (i.e. the previous release).
I may downgrade regardless, but I'm definitely out for blood when it comes to this datalink antenna. It needs to die. I'm not against applying wire cutters for a permanent "fix", if that's what it takes to render it inoperable.
Just need to figure out what's involved getting back there and what to disconnect/sever.
Greetings
I've been lurking around for a long time but never really had something I thought significant to share until now. I think I can help…
I never activated even the trial "Access" because, after reading the privacy policy, i disagreed with feeding operational data from my vehicle to who-knows-where-and-why. The proof-of-concept exploit didn't really scare me but after reading quotes from FCA claiming they know everything about how all their products are being used, it's pretty clear that they don't need anyone to agree with their policies to siphon data so it's time to AirGap the Rat.
Yes, the CDMA radio has a unique antenna. And it can be disconnected without compromising the satellite and terrestrial entertainment radios. That's good news.
Satellite-delivered services, like TravelLink, are not affected if the CDMA radio is disconnected. More good news.
Not-so-good news: That radio knows when it doesn't have an antenna and posts a nag screen to have the "vehicle phone serviced". Although the screen can be dismissed or will time-out after a few seconds, it's still a nuisance and will occur each time Uconnect initializes. The "no service" indicator on the rearview mirror is also lit.
Next step is to see if there's DC power on that port to help to decide if I can terminate the antenna port with a dummy load to appease the radio, so I'll be shopping for connectors for a little while - maybe a trip to the junkyard - and hope to offer some more findings before too long.
I'm also curious about just where this antenna is…..sharkfin? dashboard? Perhaps minor details, but if it's in the dash it might also be tamed with a shield……tinfoil hat, anyone?
Anyway, I hope this helps.
In the meantime, here's what I know, for others who also might want to pursue the air gap:
(Connections in the back of the Uconnect head)
White - am/fm terrestrial radio
Green - for sat + nav radio
Pink - for sat radio only
Red - CDMA radio
There is another White connector body, larger and away from the antenna cables, that connects to the USB hub.
(some pics)
The cables…
CDMA connected… (sorry 'bout the glare)
CDMA disconnected, TravelLink lives!
Nag screen…
No service…
Subaru Legacy STIEVO
I am reporting no problems with the 15.26.1 update. The previous one (year old) was buggy as the radio would occasionally have to be reset.
I would be careful with the wire cutting initiative. I would not be surprised if some feedback mechanism existed and once a cellular signal would not be detected, you get some dreaded error message that requires an expensive visit to the dealership.
I find it safer to hack the installation and delete the Sierra Wireless driver from the ISO. If anything is bad, then install the full, unmolested ISO.
1 - 20 of 285 Posts
