I want to tie into the front electrical connections on my stock foglights.
Ideally, I'd like to find a supplier for a T or pigtail connection that can fit between my foglight wire and the foglight.
Anyone seen such a thing before?
Long Live the Grey Ghosts
Autolumination.com has lots of extensions. Get a extension with a male/ female ends. Then tap into the extension with solder or those snap clips. All OEM is intact. You only cut into the extension.
thanks, I'm also going to check into what the vendors like lxharness and taillight solutions would offer.
i have always found a great selection of extensions on ebay
this is the route I finally ended up going. When the extensions arrive, I will make my own setup.
I will post a pic when it's done in case someone else wants to do the same.
