1 - 20 of 98 Posts
2006 WK
Thank You
2022 Grand Cherokee L Laredo
Is this still an active code? I am going to be starting and finishing exterior LED conversion SOON.
Please do a write up on the exterior conversion. i have heard too much of fuse blowing to waste my money doing it before doing it the right way.
The only ones you really have to worry about are the front blinkers if you are using aftermarmet LED tails like I am. The only LEDs that I will be installing (if the code is still good) will be the Reverse, license plate, and front park/turn lights. So the fronts are the only ones that I will need to install a resistor for.
Discussion Starter · #9 ·
The code should still be good! And yes, you will need the resistors for the fronts only!
i am going to be talking to them tomorrow! probably placing an order. where is this code? i want to save 15%!!!!!!!!!!!!!!!!!!!!
how long are these good untill?
05 WK Laredo
When I talked with Vleds Bill said all the discount codes might be up starting the new year. Try them though and see if they work. I sent him an email seeing if he wants to be a vendor on this site. That would be cool.
05 WK Laredo
The interior leds I bought off ebay for considerably cheaper, but I went thru 3 different sellers/types in order to be happy with what I have now. The first ones I bought were a "kit" off ebay but they looked blue to me, so swapped everything out till i found ones I was happy with. I def could of just went with Vleds in the first place for the money I spent in trying different bulbs, to get a nice white color. Doing it over I prob would just go with Vleds since they have pretty good reviews.
1 - 20 of 98 Posts
