1 - 20 of 26 Posts
2011 GC Limited - V8. About 6k miles and things should be broken in enough now.
Have two annoyances; First is engine shudders/vibrates, mainly when the ECO light comes on. Not every time it comes on, but enough to notice. Second is when accelerating from a stop or low speed it feels like something in the driveline is slipping then grabs – jerking the vehicle. Best way to describe it is like the tires slipping on wet painted lines at a stop sign, then grabbing dry pavement.
Thoughts???
I'm having the same issues with mine. It just keeps getting worse. Dealer claims its the MDS but there is no way. I just keep taking it in and complaining and they do nothing for me.
Yes on accelerating from a stop I get a succession of large clunks in transmission... Almost like traction control except I do not have to be accelerating hard. It's not normal, and if it is someone has done something wrong!
2012 Overland ORAII
Try shifting your ERS (electronic range selector) out of drive and into 5 and see if it continues. On mine this seems to stop the confusion going back and forth out of MDS and keeps ride vibration free, doing this made me realize that I may have a tire out of balance also. I have a '12 with the "6" speed 5 speed and I put it in 5 as 6 seems to be a gear for 95mph+ and even with the ERS on 6 it wants to be in that gear on the highway and it is too tall.
Regarding your second issue, does this sound similar? If you read down I posted what they fixed, yours may not be as bad as mine and plus the fact you don't mention you're throwing any codes but it may be somehow related. Also I must say that after a few weeks now I am happy with the repair.
Richl
Discussion Starter #6
Richl - what issue did you have and what was the fix? What post are you referencing?
I have had the Jeep in the shop 4 times (or was it more....?) in the first 3 weeks of ownership for a number of things - including the above listed. They said they had a tranny tech look into it and found nothing (um.... ok!) No codes so it is more of a 'seat of the pants' diagnostics.
This is my wifes daily driver and apart from the silly issues (now fixed), the tranny thud and the engine vibration is really annoying her (and then me!)
Thoughts???
I am assuming (from my own experiences) that the shudder/vibration mostly occurs cruising at highway speeds 50 - 60 MPH, on slight incline with light acceleration and it feels like a engine misfire? If so, I wish you luck getting anything donw that actually fixes this issue. Mine started after approx. 3,000 k and continually got worse up to about 30,000K and has been in for every update, had a recorder installed for days, Chrysler tech checked it MANY times and final statement from Chrysler customer service and the dealer was that after "break in" it is normal for this issue due to MDS activation, lean cylinder mixtures, torque convertor locking and unlocking along with what they indicate is a "controlled misfire". This absolutely drives me crazy but am stuck. Now have 42,000 on mine (I drive a lot so probably experience this much more than many others) and am just "living" with it. I HOPE yours does not progress any further or it is not the same. Totally unacceptable IMO to have a modern vehicle do this but I have exhausted so much time and effort over the past year trying to get something done and am just plain tired of it!! It will be the last I will buy from them. The worst part is I bought this because I liked everything about it AND IT DID NOT DO THIS WHEN NEW!!
From what you described, it sounds like mechanical parts on the Jeep just wear down slowly over time and miles.
Leave it to me to leave out the link to my thread, momentary brain clot I guess
Here ya go.
http://www.jeepgarage.org/showthread.php?t=30834
WK2 Limited
I have only 350 kilometers on mine (european version with 3.0 CRD diesel engine) and I notice this strange vibration 3 days ago. I don't understand yet if it is a transmission or brake or whatelse vibration, and it is not always present.
It seems that it occurs when the engine is cold, but not sure; always in deceleration or very small acceleration.
I tried putting in tow/haul and manual shifting and it still does it. I'm giving jeep one more chance to fix it then I'm getting a lemon law lawyer (yeah I know good luck). It has been in for warranty work for twenty days so far so ten more and it's eligible for the lemon law here in GA. I'm so frustrated. I thought jeep was better than this.
Discussion Starter #12
update.....
the Jeep spent 2 days at the dealership (a different dealership) I brought in the print outs of the TSB's and tried to show them - they didn't want to see them. Explained what was going on, took the mechanic out for a 15 minute drive - and of course it barely did any of the issues. Go figure.
They claim they applied the update for the MDS issue - I could not tell any difference and still feel the droning. They could not duplicate the acceleration thund/misfire like symptom (yet the mechanic did feel it a little bit when he drove with me). NO ONE inthe dealership had an iphone or ipod to test the fast play issue - really?
Got a call from the survey people today.... had to pull over and let them know how I felt. At the end the lady asked if I would like someone from Chrysler to contact me to discuss further? Hell ya I would! Let's see how far this goes and for how long. ugh.
Jeep wk2
So far my v8 limited 4x2 is ok (600 kms) but i am starting to get concerned on this issue and the other post about shuddering.... Expectation was really high on this vehicle....
Saw this thread and maybe its more related to the one I started a few weeks back. Again I have a transmission vibration when I accelerate from a dead stop. Today it happened very badly... almost like the wheels were slipping on gravel until the car got traction.
I plan on taking it to the dealer next week but Im not sure what to say to lead them in the right direction. I feel like simply saying "feels like its slipping" will make them come back with some BS excuse. Any help from people who took it in for the same issue would be appreciated.
Mine feels like I'm running over rumble strips sometimes when it's not shuddering and vibrating.
I just made a service appt for the 24th. I'll let you know the outcome. I'm also having my sunroof rattle looked at.
2012JGC; 1997WJ
The MDS issue is not the issue causing a start from 0 mph, that seems obvious. I think I can say I've experienced both of these issues in my '12, but like my own personal aches and pains in my body, I ignore the small stuff!
I think the MDS issue is the inherent imbalance of turning off 4 cyls. They try to balance it, but it is hard to do and imperfect, however, Chrysler does say they really have no evidence it is hard on the engine after about a billion miles of use, so ignore it, if you don't want to ignore it, put it in tow/haul or manual shift to 5 or 6 to deactivate it and you're done...
The other issue I am thinking is the transfer case slipping going to the front wheels and not giving a smooth start. I find mine to be variable and frankly, I ignore it and consider it within spec, but if it's bad, I'd have them look at this. Of course it could be in the computer control of the hardware so maybe there is nothing a mechanic can see or measure... I agree with above suggestions, shift to manual shift, or tow/haul or, too, try turning off the hill brake assist. Mine was off on day 1 when I quickly realized it was working too hard and interfering with startup even on level ground.
I'm not saying ignore problems, but if the car is under warranty and something is really wrong, it will probably break under warranty if the dealer won't fix it now, so I just drive it.
1 - 20 of 26 Posts
