Anyone ever felt that. Its been an issue for the past month or so. At or around 2k rpm and at about 60 -65 mph with my E group there is a slight drone and vibration in the gas peddle. No loss of power or anything like that, but I certainly noticed it.
Its a slight drone that goes in and out.
Anyone else ever experience that?
I had a vibration/buzz sound around 1500 RPM and the issue was the heat shield vibrating against eachother. The heat shield comes in several pieces so if you get below and slightly bend them so they don't touch it could solve your problem. It was a simple fix for me and saved a trip to the dealer. Not sure if this is your problem but it is worth a check...
Ok, will definitely look at that. Just out of curiosity, where would I find it?
