1 - 1 of 1 Posts
Overland
Has anyone experienced this same issue?
Over the past few months, I noticed when I start the jeep remotely, sometimes the “Voltage Warning Light” illuminates after the engine starts up, the light stays on. The charging system is not charging when this light illuminates. This happens about 50 % of the time I remote start.
If I put the key fob in the slot, turn the engine off and re-start the engine using the key fob, the engine starts, and the “Voltage Warning Light” turns off like normal and Alternator is charging 14+ volts.
When I start with the key fob, everything works as normal.
No Codes. Battery 1 year old, no starting issues.
Before I start troubleshooting, has anyone experienced this same issue?
1 - 1 of 1 Posts
