That looks great and is next on my list (I installed their transmission plate last summer). However; I'm a little intimidated by the install complexity, how long did it take you?
It wasn't too bad. I was taking my time and was probably done in about 4-1/2 hours.
NOTE: if you are going to retain the oem front tow hooks, make the modifications to the mount per the directions, then install the hooks at this time. The hook are not in the way by installing them at this point.
If you wait until step 29, per the directions, you can't get to the 30mm nut on the rear of the hook to tighten them. Plus, any adjusting that may be required to the oem hook mounts so that the two front bolts can be installed can't be accessed with the sump protection plate in the way (sump protection plate has to be installed prior to the lower front guard).
Because of the supercharger, I had to modify the left corner guard to fit around the windshield washer bottle.
4 to 4-1/2 hours to install both, the Sump Protection Plate and the Lower Front Guard.
