1 - 12 of 12 Posts
first post!:D
Got a diesel Limited on the way, wondering what engine oil it uses
I looked on the Jeep site for the manual but it only has the v6 and v8 info...
'15 Grandokee Overland
Page 58 of the Supplement:
"Only use SAE 5W-30 Synthetic Low Ash engine oil such
as MOPAR, Pennzoil® or Shell Helix® which is recommended
for all operating temperatures. This engine oil
improves low temperature starting and vehicle fuel
economy."
Jeep Owners | Download an Owners Manual 2004 - 2011 | Jeep
And congratulations for being one of maybe just dozens of us who call it engine oil. Every time someone says motor oil, I wonder if they're talking about the AC motor, the windshield-wiper motor, etc., or if maybe they simply have the NASCAR accent. :)
Thank you for the info and link!
engine oil...funny, I didn't even realize my (correct) usage of it, it's just automatic...of course now that you mention it, I'm going to notice any time someone writes "motor" oil:D (but I too like referring to things as they should be:))
· Premium Member
From the manual:
We recommend you use ACEA C3 5W-30 engine oil meeting Chrysler material
standard MS-11106 or Penzoil Ultra Euro L full sythetic 5W-30 motor oil
The big part to this is Chrysler (or Fiat) material standard MS-11106, very few pass this.
So if you are doing your own oil change, make sure you cover this to cover your warranty.
· Premium Member
MY12 JGC Overland
From the manual:
Mobil1 5W30 ESP is about the only one that meets the specs that include MS-11106.
The Penrite 5W-40 has about 30% more Ash than the Mobil as well. Possibly not so good for the Particulate Filter.
I love Penrite oils, but for the Jeep I'm using Mobil. The Penrite Enviro+ 5W-30 does have the lower Ash level like mobil, but doesn't have MS-11106 and the HT/HS value is slightly lower than the Mobil.
· Premium Member
You're in Australia, there is no question or option here. Mobil 1 is the only oil in Aus that meets MS-11106.
The Shell used to and probably still does technically, but it no longer says it does, so not worth the risk for warranty coverage.
1 - 12 of 12 Posts
