ok, technically, if the 13s and 14s are running the same wheelbase and chassis, shouldn't things like running boards and wheels be the same specs and interchangeable?
Wheels probably, unless they changed the bolt pattern for some reason (which they most likely didn't). Running boards also highly likely, unless they had to modify the mounting points due to floor pan changes for things like CRD emissions stuff.
