1 - 2 of 2 Posts
I need some help guys. Here's the short version: 04 Laredo 4.0 selec track. It snowed last night around here so I threw it in 4 full time on my way home. All was good and melted in the morning so I shifted it back to 2wd while coasting at about 20 miles per hour with no throttle at all. Now I can't make tight turns and it seems one of the wheel binds while trying to turn. Also there is a light whining nice while driving coming from the front end. Stock axels, 3" IRO lift.
I should also mention I tried shifting the transfer case in all positions while at stop and while coasting at about 10 miles per hour with the transmission in gear and neutral ( and no I did not shift in 4 Lo while coasting just at dead stop with the tranny in neutral ).
All ideas and help welcomed...
The beast from Brazil
Did you check the fluid level in the T-case? Was the T-case fluid changed lately?
1 - 2 of 2 Posts
