1 - 18 of 18 Posts
On the Ram Ecodiesel it's just below the oil filter on the housing. It's the upper sensor with the single wire. Maybe similar on the Jeep?
I don't own a Jeep. Was just trying to help in case it was similar to the Ram.
If you buy the part from a dealer they will have a diagram you can ask to see.
If you buy the part online there's often a parts diagram you can view.
Lifer: Old Geezer
Overland
I know.
Thought the spot is maybe identical.
No diagrams online and dealer wont tell except he can do the change
Try Google, and check out the images.
3.0 diesel oil pressure sensor location 2014 jeep grand cherokee
No idea if the one on the diesel is as prone to failure as the ones on the old 4.0 six
Truck
It is on the left side (drivers side) of the engine just behind the oil filter housing. The upper sensor is for oil temp and the lower one is for oil pressure. I have a picture but it is a pdf and is to large blah blah and I can't figure out how to post it.
Truck
Not to be a smart a**, but if you bought the part it should be fairly simple to locate it at or near the oil filter housing just by looking at the part itself..
1 - 18 of 18 Posts
