There are various threads that talk about power for a dash cam. Some have taken power from the mirror but I took mine from the media console.
ok, so I found the tech tutorial on tapping off the power in the center console... I did, and unfortunetly looks like the 2018 is a little different-- from what I can tell, looks like you tapped off the third switched wire on the three-pronged connector that goes into the cigarette lighter -- while the '18 has the same connector, only two wires... red and black.
There's one giant bundle of wires under the console, I tested every non-black wire with ignition on and off, none are switched. Well, one is, only it's 12 volts immediately on shut down, but then drops down to 3 volts.... so, no good for me.
any other thoughts? the device I'm trying to connect is for now mounted in the center console.. anything switched in that area on an '18 I can tap off?
