Anything is possible of course, but the only time I have seen that fuse array blow is when the vehicle is improperly jumpstarted or one of the battery positive terminals was shorted to ground
Neither are likely unless something shorted while driving. I suspect it has something to do with the auto stop/start since that's when it occurredAnything is possible of course, but the only time I have seen that fuse array blow is when the vehicle is improperly jumpstarted or one of the battery positive terminals was shorted to ground
Don't know what they did. Not impressed with them so far.Did the dealership thoroughly check the battery compartment?
Perhaps something was in there that could have caused a short?
Thats an interesting theory........Searching the forum I found a reference to a "rogue" alternator.....
So far no further word from them after I refused to pick it up when they just replaced the block. Reached out to service manager to see if he can light a fire, but I still suspect the alternator failed. And yes, I think the batteries are toast but they checked and said they were good. I have doubts. They also wanted me to pay for the fuse replace and I refused that as well since if a mechanical or other under warranty item failed, then that should be covered as well.Thats an interesting theory.
Just some wild 'what if's' brain storming.
If the alternator's field intermittently shorted internally, complete shorted diode bridge or the field control wire from the PCM shorted, the alternator could of went full voltage balls with no voltage regulation.
No telling for sure what would happen but i'd think the batteries would probably be toast and the fuse too.
This doesn't sound like anything you did since it happened while stopped at a light where the small ASS battery comes into play to power the electrical system while stopped.
Did the dealership at least take a look at the batteries for any traces of a short to ground?
Sometimes a short circuit to ground can fix itself by blowing open the short contact area but that would definitely leave tell tale clues especially considering the large amperage fuse blowing.
If the dealership found no root cause for the fuse blowing might want to be prepared for it to possibly happen again.
Tell the service manager since they found no root cause you have zero confidence that it won't happen again.So far no further word from them after I refused to pick it up when they just replaced the block. Reached out to service manager to see if he can light a fire, but I still suspect the alternator failed. And yes, I think the batteries are toast but they checked and said they were good. I have doubts. They also wanted me to pay for the fuse replace and I refused that as well since if a mechanical or other under warranty item failed, then that should be covered as well.
5K miles? Did it sit on the lot for a while, and could it have been scavenged for a part, like a fuse? I recall some car parts in short because of supply chain problems.I have a 2022 Grand Cherokee (WK) with 5k miles...
Is the dealership just incompetent or could a 150 amp fuse block just go?
