1 - 10 of 10 Posts
Hello all,
I'm hoping if there anybody who can offer me some guidance....I have a 2015 limited (love it and never had any issues) with just over 39k miles. Needless to say it's time for new front brakes. My question is, Does anyone know if FCA will void or question my maxcare warranty if I replace the pads and rotors myself ? I plan on using Mopar parts. For what it's worth, I've worked on every vehicle I've ever owned in the past and am a licensed aircraft mechanic. Thanks in advance.
Dr. K.
No, it will not "void" your Mopar Maximum Care Extended Service Contract. In the US, that wouldn't be lawful. Keep records just as if you had the dealer or other qualified entity to do the work.
Well it would void the warranty for the work you've done yourself and ramifications from that work.... ....for a set of brake pad and rotors, I can't imagine anything but the labor on the brake pads and rotors... ...perhaps if you had a torn dust shield or a brake hose obviously damaged by letting the caliper hang from it, they may give you a problem for those things.... ...but I don't think you're likely to run into any problem...
2015 WK2 Overland
It will not. I've swapped to different rear calipers than originally equipped so it is to be expected that MaxCare would not cover those in the even of a failure. But it's cheaper for me to replace a caliper than to pay the $100 deductible anyways.
Reactions: Mongo53
Brakes are not included in the extended service contract (or OEM warranty) but yes, if it could be proven that there was negligence with the work, they might put up a fight over any damages caused by the work. But they cannot "void" the contract for non-related things, like the entertainment system for shoddy work on the brakes.
Reactions: Mongo53
Discussion Starter #6
Much thanks to all who replied. I went with OEM parts so that if ever a question arises it's all Mopar, err FCA. Next on the list....tires.
As others have said, consumable items like brakes are not covered past the bumper to bumper in any ext. warranty i've seen.
However i'd keep the part receipts just in case if nothing else for your maints. records.
Replacing the brake parts with Mopar OEMs would be added insurance though not necessary.
Hello all,
Dr. K.
On paper, you should always keep all the original copies of service receipt/proof if you were doing maintenance yourself. But reality is, dealer really don’t ask for those if they are doing any under-warranty repair, trust me.
2014 Grand Cherokee
The problem would come in if the warranty is denied for some reason and you have to prove that you complied with the service requirements. It happens rarely, but it does happen.
2015 Grand Cherokee Summit
I had the same concern. I'm going to comply as much as I can but I can not pay $500 for spark plugs so I bought the new OEM plugs and seals and replaced them myself. when I do the next oil change I may still by the Jeep filter and oil. Next I'm going to do the front and rear brakes and I'm going to buy the OEM pads. most time OEM parts are better than the aftermarket part anyway.I have 80000 miles on the OEM brake pads and they still have some meat on them thats unbelievable on my ex wifes benz they would last 35k and sometimes 32k.
1 - 10 of 10 Posts
