1 - 20 of 21 Posts
im pretty sure you guys heard over and over of a wj srt..... but mines is going to be the most original! im not going to be using 20 inch srt8 rims. im going to be using the original wj Rogue rims... and build my own SRT. i already lowered it and i want to put an exhaust that isnt TOO loud but when you press on the gas.. it sounds like you shouldnt mess with it. Just give me some idea.... because i want to be original!
P.S since ill be using Rogue rims. what is the widest tires i can put
Rim- 17x7.5
currently have 245/65/r17
Want to Have- 275-65/r17
We ran 275/55 r17 on our 02 with the chrome rogues. Gave the jeep a nice stance, no rubbing, and speedometer did not need to be recalibrated. For reference, ours is a limited and not an overland. I miss those tires, I think it road better.
· Boosted Turd
2010 JGC SRT8
It just un-bolts from the top lol. But you will need some christmas tree clips and clear silicone to plug the holes. How far are you lowering it? There is not much room at all between the axle and bump stop with stock suspension.
· Boosted Turd
2010 JGC SRT8
As long as you keep the same overall diameter front and rear your good. Tire width does not matter, there is a guy running a staggard set of reps without an issue.
That would be me. 9" OEM SRTS in the front and 10" in the rear. Had some rubbing issues in the rear.. Installed a 1/4" wheel spacer and rubbing is gone! Also installed Bilstein 45 series shocks and installed a rubber "accordion style" boot on to move it further away from the wheel. Tires are P255/45ZR20 up front, P285/40ZR20 out back.
2013 JKU Sahara
Do you have a hitch on it? If not, a center exit exhaust hasn't been done yet on a WJ (that I know of)...
I really want to do that but don't wanna lose my hitch. Could do a custom drop down hitch?? hmmmm
· Premium Member
WJ Limited
There has been a center exhaust done but I can't think of who it is off the top of my head. He has silver jeep, Gen III headlights, green and I think black side stripes, green calipers, CF on hood and roof....dang, the names on the tip of my tongue but can't think of it.
2013 JKU Sahara
Greenwithenvy I believe is who you're referring to....
2013 JKU Sahara
Yep, there's a vid of it around here somewhere too.
I've heard that about you brother...:lol: Hey, it made the Kardashians famous. I don't blame ya for posting vids of your "center exhaust"
2013 JKU Sahara
· Premium Member
Greenwithenvy did it. It required custom exhaust work and not a whole lot of room. As well, he lost his hitch.
You two are so cute together.
Reactions: TJXJWJ
1 - 20 of 21 Posts
