Here is an example enclosure that fits into the WK cargo area flush with the angled floor as well as the angled rear seats.
Wing template PDF is attached at the bottom of this post.
- This enclosure is meant to house woofers up to 10 inches. The design can be modified to house a 12 inch woofer
- The total (gross) volume of this particular enclosure is 1.145 ft^3
- This design uses 3/4 inch stock
- Note the mounting depth when shopping for woofers: I wouldn't go any bigger than 5.5 inches with this design
- When selecting a woofer(s) remember to account for displacement
- Keep in mind, any bracing will reduce the volume of the enclosure
- This design allows the owner to retain the ability to use the factory cargo tray
- This design allows the owner to retain the ability to use the cargo shade
