These are common or recurring faults with these vehicles. Our members report problems with their Jeeps.
Please don't hesitate to ask if you do have any questions.
Hey fellas, please read and adhere to this to keep the thread more easily controlled.
When you post in this thread, please ensure the issue is related to the correct heading as listed below.
1) Add your information by copying/pasting the ENTIRE section your comment refers to for ease of thread maintenence.
2) Describe the problem in detail and/or relate it to a confirmed technical Service Bulletin (TSB).
BODY EXTERIOR -
- early failure of hood struts and hatch struts not uncommon.
- Hood out of alignment.
INTERIOR -
- rear folding seat strikers rattle when seats are in up position, there is a TSB for the dealer to replace strikers.
- Cloth seats stain very easy. TSB on this for the dealer to wash for you once.
- Steering wheel can make slight "grinding" sound on occasion. Dealer disbelieves.
- Passenger seat rattles at highway speed with no passenger in seat. unsure if there is a TSB, i could not find one, everything seems tight.
- Can confirm that the dealer will replace a worn leather steering wheel within warranty period.
ENGINES -
3.0 CRD - Swirl motor may make a chattering noise. This is the vacuum pump failing. Will result in very bad performance.
- Fuel injectors need to be reprogramed if they are replaced or the engine will not run.
- Turbo inlet hose can loosen causing noise and oily residue - fix it to ensure clamp is tightened regularly.
- reports of oil temp sensors leaking (just a leaky washer).
- several reports of sump gaskets leaking.
- Not so much a warranty issue but MANY diesels have been drowned with catastrophic engine consequences. The air intake is vulnerable on all WK's. You've been warned!
3.7L - On some vehicles at cruising speed there is a whine that comes from the throttle body. There is a TSB for this issue what is happening is that as air passes over the joint/seal in between the throttle body and the intake manifold, if there are any voids at all in that joint it creates noise. Essentially the TSB shows you where to judiciously apply RTV in that area to fill in any voids. This is an assembly fault at the factory.
4.7L - Exhaust manifold chatter due to loose manifold bolts. Most people remove, check for warpage, and replace the bolts.
- 2005-07 4.7L Stalling under multiple circumstances, After hard driving, after regular driving, whole at running temp, while cold. From moving to a complete stop, idle will drop well below 500 rpms and occasionally stall out. TSB, requires reflash of computer or possible need to slightly over fill tranny fluid, ATF+4, Possible crankshaft position sensor, (not confirmed on 4.7 yet)
5.7L - Must use correct grade oils to maintain proper MDS fuction and avoid "HEMI tap".
- electronic throttle has massive delay intermittently... dealer has reflashed but problem returns. MAP sensor and elec throttle control parts on order.
- Repeated stalling due to a faulty Crankshaft Position Sensor (had that replaced).
- Third starter on an 06 limited Hemi. QBNKID said the OEM starters suck. When I actually have to pay for a replacement, I will go after market.
- 05-07 models have delay issues with electronic throttle. Dealer rplaced MAP sensor on inlet manifold and installed updated throttle pedal (requires wiring modifications as it's a new design). Can report it is much better now. Will reconfirm in 1 month. - Confirmed, STILL GOOD!
- Power steering pump failures relatively common.
6.1L -
TRANSMISSION - QuadraTrac (QT) or QuadraDrive (QD)
- Service 4WD System light can illuminate and chime regularly. TSB to re flash and tighten connectors.
- The trans wiring harness seals can leak trans oil on a fairly regular basis.. there is an updated adaptor that apparently fixes this problem.
- well documented HEMI "shudder"- unfixable. (I believe torque convertor lockup fault).
- Have heard of cases where the transmission has overheated in extreme sand condition causing the car to go into "limp" for 15 minutes.
- Several reports of slow gear engagement after extended lack of use period. There is a flash "21-016-0509/01/05RFE TRANSMISSION - DELAYED ENGAGEMENT AFTER AN EXTENDED OFF PERIOD" for the tcm and various levels of success reported.
DIFFERENTIALS -
- rear diff whine at 65mph. Replaced ring gear and pinion all fixed under warranty. (after 2 years!)
- Front diff needed new bearings at 100,000km, and now front drive shaft has gone at 150,000.......all mostly open road work 30% on graval roads.
TRANSFER CASE -
SUSPENSION -
- Front sway bar bushes on their way out, likey deny warranty claim due to larger wheels fitted.
- front differential mounting bush fail at 56,000klm. warranty fix.
- creaking rear suspension. There is a TSB to replace upper rubber spring bases on some year models.
- rear upper and lower control arms + track bar (stabilizer bar) completely gave out at 55,000 miles ... started making real loud rattling in rear cargo as if the whole car was moving side to side ... had them replaced and now no noise. This was on a 2006 3.7, manufacture date 02/06.
- Sway bar links on a non-srt wk fail earlier than expacted.
- Reports of standard shock absorbers failing as early as 33,000 miles, but many people would argue that the entire shock absorber valving setup on a standard WK is a failure from the beginning.
ELECTRICS and ELECTRONICS -
- Dealer fit rear seat DVD failure causing flat batteries. (twice)
- FOUR batteries to date (partly due to DVD issue above). Note that CRD battery does not accurately fit petrol engine bays.
- ABS cycles when slowing uphill. I heard TSB to fix, dealer denies this!!!!!!
- Dealer fitted Satnav touch screen failure (pertains WH export only)
- Sun/moon Roof will not close or open, TSB reflash of the computer.
- Multifunction headlight switch/stalk - Several people having problems with them not having the proper connection. Causes lights interior/exterior to go NUTS sometimes! flickers, dims. And when the stalk is given a nice bump, they go back to normal.
WHEELS and BRAKES -
- front rotors required machining at approx 40000 miles.
ACCESSORIES -
- Tow bar WILL loosen over time. Ensure bolts are re-checked at regular intervals.
- Ensure dealer installs tow pack correctly. There has been instances where the steel crush sleeves for inside the chassic rail have been left out resulting in catostraphic chassis failure.
MISC -
---------- Post added at 01:04 PM ---------- Previous post was at 12:28 PM ----------
** it would be great if an owner of each model represented in our group would take a few minutes to start one for their model jeep. Feel free to use this as a template
BODY EXTERIOR -
INTERIOR -
ENGINES -
6.1L -
DIFFERENTIALS -
TRANSFER CASE -
SUSPENSION -
WHEELS and BRAKES -
ACCESSORIES -
MISC -
