Hi All, just a heads up to check under you WK2 i had some bolts come loose and fall out on both sides, not sure exactly what the correct name for these brackets are but I'll try and find and attach pictures showing after i fitted new bolts back in, i locked them in with some engineering adhesive. Maybe me going over rough ground but worth checking. They are next to front wheels and branch towards the rear engine mount or bush and should have about four bolts in.
Here's a detailed thread about them, including torque specs for the bolts.
