1 - 20 of 71 Posts
Heres a couple of pics of my install of the factory Mopar rock rails for the WK2. Thought I would start tonight while I had a couple of free hours. First all the hardware is accounted for! :thumbsup:
Second the instructions said to dry run each nut on its bolt. I found this is for good reason due to the coating. Very tight! You'll run in to trouble later if you don't!
Next removing the rockers are a bit tricky as I found. They recommend a hook style tool. I had none and ended up ripping a couple clips apart.[ IMG]http://i494.photobucket.com/albums/rr308/dvdsjk/IMG_20110204_222830.jpg[/IMG] Now you have to bend and manipulate the rear bracket up and out of the way to use later. First pic I hit a little too hard . Second pic is the way its supposed to be. I reccommend havig some touch up paint handy due to paint coming off during this process. not to mention an accidental scratch or two!
Last for tonight start inserting bolts in existing holes on the body . Some must be cleared of foam insulation. Then with the supplied hex head tool they give you, A bolt is installed in the rubber plug holes on the bottom of the rocker to the rocker side holes. this is done by bending tool 90 degrees and locking in place with a speed nut. Tommorrow I will dry fit and mount the drivers side.
This looks like it may be a pita, but worth in it. Can't wait for the photo.'s.
Ok,day 2 starts out bad, closet full of cancer causing chemicals but my Locktite is nowhere to be found. Run to NAPA.
Now have all the bolts in place and time to lift. Careful, the directions say put a rag on your jack so you don't scratch it! Ha!
Start bolting up from front to back.
And of couse problems. The bolt system I feel needs to be looked at. Bolts are short and not an exact fit. Ended up causing a major F up. Will address this later but for now on to pass side.
Discussion Starter · #9 ·
Thanks guys for the positive comments! Pass side now on. No problems on this side! I really under estimated this one though! I should have arranged for my buddy to give me a hand. Would have gone a lot smoother and quicker. Looks good though, and all I have is some finish work tommorrow such as cutting up the old plastic rockers to use as ends for the rails. No they don't include ends! Also fixing the nut on the drivers side that I screwed up. Tommorrow I'll get some outside picks hopefully posted.Heres a couple of pass side.
Waggie
Nice work, thanks for the write up. Looks like a PITA with some knuckle busting and choice expletives. + rep.
Nice write-up! + rep!
So how long do you think this job will take the average owner?
Discussion Starter · #13 ·
I dabbled with it because I knew I was in no hurry and I was in my own garage. But I think it took me about 8hrs by myself. But thats with time spent on that 1 bad bolt that stripped on me. I struggled at first tryng to take the plastic rockers of carefully, but you have to cut them up to use for end caps anyway. The pass side I just yanked off. Then the rocker stiffeners took a few mins because its all underneath the Jeep on the damn cold floor!
They look great! You have much more patience than I ever could. Good job and thanks for sharing the pics along the way.
Thanks for the nice writeup.
Question for you:
My wife is pretty short & has trouble getting into the WK2 sometimes.
I can't STAND the soccer mom look of the Mopar step bars.
Is there enough surface on these to serve as a step bar for everyday use, or is the diameter of the rail too narrow?
Quadra-Drive II
2020 Trailhawk
Great Job! They really look good and solid!!!
Is it possible to re-use your front mud-flaps? Will they work in conjunction with the Rock Rails? I'm assuming that you had them on the front as you currently have them on the rear. I understand they may not work well off road or may not even look good with the Rock Rails but I like the protection they give on gravel roads. I have a set of Rock Rails on the way and I currently have front molded mud flaps on the front is why I ask.
Also, the plastic rocker panels are they reinstalled? Or is it just the ends that you cut off and reinstall?
If I have trouble installing mine in a few weeks….I will probably PM you...OK?
1 - 20 of 71 Posts
