Yes, you can put the damaged cams back in and replace them at another time, BUT...you may still have ticking and you may end up damaging the new rockers...That being said, on customer pay jobs, I have reused cams that were damaged on the outside of the lobe and never had an issue...( I always give the option to reuse or replace) just because there is a wear mark, does not mean the cam is bad..
Warranty always gets new cams
I wish I had a picture handy to illustrate it but what happens is the roller bearings in the rocker go bad allowing the body of the rocker to hit the cam and wear it out on the outside edge of the lobe.....putting a new rocker on restores the rockers ability to only ride on the center of the lobe and is perfectly fine .
so long story short,if the center of the cam where the roller rides is not damaged, you are perfectly OK to reuse the cam .
