1 - 20 of 51 Posts
After searching the forums I have found that it is difficult to see what type of tire/wheel combos will work for my WK2. I am proposing everyone that has tire/wheels that are not stock to please reply to this post and follow the format given below. Please do not post pictures in this thread to keep the page size down. I will add the chart soon from info I have gathered. If the category does not apply use N/A or stock.
Overall Tire Diameter | Tire Size | Wheel Width | Backspacing | Offset | Lift | Wheel Spacer/Adapter | Tire Brand/Model | Trimming required Y/N |
Example:
30.5''|245/70R17 | 8'' | +55 | 2.5'' | 1.5'' | Goodyear Wrangler Duratrac | Y |
or if you have Quadralift:
30.5''|245/70R17 | 8'' | +55 | QL | 1.5'' | Goodyear Wrangler Duratrac | Y |
NOTE: IF YOU LEAVE INFORMATION OUT I CAN'T ADD IT TO THE DIAGRAM.
Tire/Wheel Set-up List
Trailhawk
a bunch of ppl are running 275/55/20 on their stock 20x8 rims. I bought a set of Cooper Zeon LTZ in this size. They say it clears the front bolt, not by much but does and no rubbing so we shall see when I get the mounted.
WK2 GC Limited
I would like to run cooper Zeons in 285/50/20. Does anyone have any experience with this size? I don't have QL but it is booked in for a 40mm suspension lift.
Thanks
Trailhawk
I ordered tuhe Zeon LTZ in 275/55/20 for my non Q L Altitude.
Sent from my SAMSUNG-SGH-I997 using Tapatalk 2
Good Day,
Just dumped a set of Lorenzo 030 Gloss Black - 22x9s with 305/40/22 on a 2012 GC Laredo with no issues. The ride is a bit stiffer with 35psi but will adjust after a few 100 miles on them. The 6.75 backspace and +38 offset work great and no rubbing anywhere.
12 GC Overland
Thanks
I have this set up with no issues. I decided on this size after another member here had it also.
Trailhawk
whats tue difference between 285/50/20 and 275/55/20??
12 GC Overland
285/50: Section width=11.22 Sidewall height=5.61
275/55: Section width=10.82 Sidewall height=5.95
Administrator
I have 285-40-22's on 22x9 wheels. Beofre that i had 22x9.5 with the same size tires and lowered 1"
Trailhawk
Well my Cooper's in 275/55 are in and am going in a few hours to get them mounted. Hope they fit. According to ppl they will clear the ball joint by then skin on my chinny chin chin so lets hope it is the same with me.
Just put on some Falken Rocky Mountain ATS tires on in 285/50/20. I mounted them on 20x9 SRT 8 reps with I believe +35 offset. Fit perfect with no rubbing.
Discussion Starter · #14 ·
I'm testing a new image hosting website. Let me know if you guys have trouble viewing. Also, continue posting your information and I'll update the diagram when I can.
2012 Grand Cherokee Limited 5.7
:D SOLD :D Going in to Discount tomorrow and getting them Ordered :thumbsup: Thanks to all of the Members that "TOOK THE BULL BY THE HORN"
:thumbsup: :thumbsup:
Well got them on BUT about 100mi and the got a eng light ! shifts from 1st to 4th ok but will not shift into 5th or 6th (overdrive) :confused: anyone else have this ?
Dah! My Jeeps
Good Day, Just dumped a set of Lorenzo 030 Gloss Black - 22x9s with 305/40/22 on a 2012 GC Laredo with no issues. The ride is a bit stiffer with 35psi but will adjust after a few 100 miles on them. The 6.75 backspace and +38 offset work great and no rubbing anywhere.
Smart1800
Do you still run that setup. Are you happy with the fit and can you post pics?
Thanks
275/55-20 Toyo Open Country AT IIs on my Summit. No rubbing at all. I need to test out aero mode some more, but so far so good even going in/out of driveways etc.
Tony
Dah! My Jeeps
275/55-20 Toyo Open Country AT IIs on my Summit. No rubbing at all. I need to test out aero mode some more, but so far so good even going in/out of driveways etc. Tony
Did you change spacing or stock 20" wheel?
1 - 20 of 51 Posts
