OK folks, here is the current status of trailer towing equipment available on the 2023 Grand Cherokee up to but not including the Summit Reserve (top of the line) model which DOES include a Class IV hitch.
In order to equip all other trims for towing, you need to order the "trailer tow prep group" which includes:
18-Inch Full-Size Steel Spare Wheel
220-Amp Alternator
Automatic Headlamp Leveling System
Full Size Spare Tire
Heavy-Duty Engine Cooling
Rear Load-Leveling Suspension
Trailer-Hitch Zoom
It DOES NOT include a hitch receiver ($420) or the required wiring harness ($405) which was a big surprise to me (and my dealer) when my Limited was delivered.
I have spent several days, phone calls, emails, and internet searches to try to find the correct part numbers- dealer's search using my VIN did not show any available. Many Mopar part searches show fitment on my model but they will not match with the VIN.
I contacted 5 different dealers and I finally was able to get the correct part numbers- there is a great deal of confusion within the dealerships as to fitment, availability, and all parts required for the install. I was finally able to get valid info from a dealer in IL. that had done the install.
In addition to these parts, a wiring harness/ brake controller is required. Many brands offer a plug and play cable that eliminates the need to rewire.
The OEM parts for my GCL (WL 2 row) are:
Hitch receiver Mopar 82219040AA (this is a class III hitch)
Wiring harness Mopar 82216041AD
This is a dealer install since much of the interior must be disassembled for the wiring.
When I gave these #'s to my dealer parts guy, he plugged them into the computer and they magically showed compatibility. I think part of the problem is the data base hasn't been updated for 2023 but JEEP has been no help. two of the dealers I called contacted Jeep and were told that there were no parts to fit my GCL.
BTW, There is also an OEM brake controller/ install kit(similar to the Redarc) that is available from Mopar: 82215834AC
I hope this clears up some of the misinformation that is out there.
220-Amp Alternator
Trailer-Hitch Zoom
