It used to up until a couple weeks ago. There must’ve been a software update that screwed it up.So, does ANYBODY, have one that works?
By no 'input' do you mean no actual oil pressure?-- is probably signifying that is has no input; as a geek that's more what I'd expect than N/A......
Like i said its probably a software glitch likely going to be or is corrected by an update especially if its being experienced by a lot, most or all owners.Of course we all have actual oil pressure….. It just doesn’t display a reading in the accessory gauge display on the center screen. Mine still displays the actual oil pressure on the dash screen.
I’m sure they will all be working next update.So, does ANYBODY, have one that works?
Not that I'm aware of, mine doesn't. 2022 SR 5.7, not L.So, does ANYBODY, have one that works?
See post above yours.Same Issue - Was Working Fine then Simply Stopped - Anyone have this Resolved Yet?
No it requires an update.. we will all get it “fixed” at the same time. Until then use your oil pressure gauge in the gauge cluster.Anyone have this Resolved Yet?
Anyone see this? I was checking my charging voltage after starting it for the first time in over a month.
Voltage was 12.5 before starting, dropped to 12.2 while cranking (according to that screen).
Started just fine. Voltage peaked at 14.5 for a good while, then eventually dropped to about 14.2 after an hour. Also about an hour of driving the Start/Stop started working again, which is typical for me since I rarely drive it
But, anyway, NO OIL PRESSURE which is obviously wrong, it wouldn't last 10 minutes I'd bet!
I did check the gauges in the main cluster (screen 2 maybe, then left/right until they showed up) and it was something like 32 PSI at idle, which is perfect to me.
(Bonus points for those bothering to figure out where I was when I took that pic)
I have a brand new 2023 Grand Cherokee limited and it is also doing this. The dealer could not do anything about it. Drove it off the lot not working correctly. After reading that many people are having this issue, I still took the vehicle. One of the other cars on the lot had the same issue. I hope there is a software update soon to address this problem. Lack of communication by Jeep is annoying.Anyone see this? I was checking my charging voltage after starting it for the first time in over a month.
Agreed, I still think it NEVER worked, but just a guess. I know several people have said theirs are no longer working now as well, but honestly, how many people looked at this and compared it to the dash numbers while the engine was running anyway?While annoying, this is really the most minor problem reported on this forum I think. I’m glad it didn’t keep you from taking the vehicle. Haha
My 22 GC Trailhawk has same issue.Anyone see this? I was checking my charging voltage after starting it for the first time in over a month.
