1 - 9 of 9 Posts
I did a search but couldn't find anything.
2022 GJC Trailhawk. Every once in a while the mirrors don't open up when the car is started. If you turn the car off and back on it fixes it. Happening to anyone else?
2022 Jeep Grand Cherokee L Summit Reserve 4x4 5.7L
I don’t have the mirror issue but my radio occasionally doesn’t turn off when I turn off the car and open the door even though I have that option enabled in Uconnect. I’d say it’s 50/50 on whether it turns off.
If i reopen the door and shut it, it will turn off.
Haven't experienced that with my '18 but i got to ask how soon after startup are you trying to open up the mirrors?
And is this only the 1st startup of the day or further starts during the day?
If you RTFM that came with your Jeep it actually mentions that the mirrors will sometimes fail to open or fold. Having been fully documented and disclosed, it's no longer a problem, and has instead become a feature. Enjoy! (Page 45.)
This happened to me 2 or 3 times when I first got the car in August, hasn't happened since then. 🤷‍♂️
I didn't see that, but I did see this, Page 50 on mine.
50 GETTING TO KNOW YOUR VEHICLE
Power Folding
To fold the door mirrors in using the Power Folding
Mirror function, rotate the control switch to the
power folding position. Rotating the control to the
left, right, or neutral position will return the mirrors
to the driving position.
If the power mirror control switch is moved again
during door mirror folding (from closed to open
position and vice versa), the movement direction is
reversed.
Resetting The Power Folding Outside Mirrors
You may need to reset the power folding mirrors if
the following occurs:
 The mirrors are accidentally blocked while
folding.
 The mirrors are accidentally manually folded/
unfolded (by hand or by pushing the power
folding mirror switch).
 The mirrors come out of the unfolded position.
 The mirrors shake and vibrate at normal driving
speeds.
To reset the power folding mirrors: Fold and unfold
them by turning the switch (this may require
multiple switch activations to synchronize the
driver and passenger mirror). This resets them to
their normal position.
This has happened a couple times on our '23. I manually close the mirrors when parked in the garage. Why they switched from the button to the knob to open/close the mirrors, idk. We're having several electrical-related issues we didn't have on our '20 GC.
1 - 9 of 9 Posts
