1 - 20 of 27 Posts
2014 5.7 Limited ORA2
As I've just purchased a 2023 Laredo WL (Traded in my Rubicon 4xe)
I couldn't help but notice something interesting about the transfer case specifications on Jeep's website.
The WL transfer case
Now the transfer case used on WK2 Trackhawks
That would be quite interesting if it is indeed the same transfer case.
Obviously the Laredo doesn't come with selec terrain but if the transfer case is capable of different modes, would be an interesting project to see if they could be modified.
Referencing the owners manual
The F45 fuse is listed as "Front axle disconnect" Won't be doing any burnouts with a 3.6 but I'll be sure to test this out and see what AlfaOBD and OBDlink software show when I monitor the transfer case.
This is interesting but I don’t know what it means. Do we have the beefy track hawk case? Does it mean that our transfer cases have the ability to torque split? I was under the assumption that we had a simple open differential transfer case. ( I have a limited model with qt1 and select terrain. )
· Administrator
The same physical transfer case can be employed in different ways in different vehicles. Keep in mind that there's a lot of software used in vehicles today to manage the drivetrain.
Reactions: 7492
I'm more surprised about the torque handling aspect. The Trackhawk has double the torque of the other Jeeps with that transfer case.
I recall a Motortrend article “2021 Grand Cherokee L Chassis Deep-Dive” that said “all 4x4 models get an active transfer case that disconnects drive to the front when it is not needed”. Maybe the “active transfer case” is the one mentioned by OP. Maybe we got an upgraded transfer case so they could implement the “front axle disconnect”. I’m curious if having clutches in the transfer case provides any advantage off road or in snow?
The QTI and QTII transfer case is essentially an electronically controlled center differential, more like an electronically controlled version of the Torsen center differentials Audi started using decades ago (that system was based on clutch packs that operated like hydraulically driven rear LSDs). Because it's electronically controlled now, they can send up to 100% of power front or rear in a fraction of a second. They advertise it as 'disconnecting' the front axle under normal conditions (presumably in AUTO/SPORT modes). This probably helps fuel efficiency.
Just my conjecture, as I haven't found any 'white papers' on the current system, but it seems like if you select SNOW, SAND/MUD, or ROCK mode, it probably activates the front axle upon selecting the mode, possibly at 50/50 (where it will otherwise activate the front axle automatically when it detects rear slip in AUTO/SPORT modes). From what I've been able to glean from various videos, cars with the rear eLSD will automatically activate the rear eLSD if it detects L/R slippage at the rear (locking it, effectively) in SAND/MUD mode, and engages the rear eLSD more quickly in ROCK mode (which requires 4 low engaged). I've also read that SNOW mode is NOT what most people might expect: It's designed to promote neutral handling, and thus will NOT lock the rear eLSD (seemingly EVER), so if you're in a low traction environment (ie stuck in the snow or driving uphill in loose/deep snow, etc) you want to be in SAND/MUD, or ROCK mode. SNOW mode is meant to promote 'stability' over anything else (ie pulling out to pass on a snowy two land road, etc).
Watching the videos of the WK2 (which also had the ZF rear eLSD) vs the WL, it's pretty clear the system was significantly FASTER to engage the rear eLSD on the WK2. This seems like a mistake, even a 'defect', but it may be by design. I much prefer the faster-engagement of the WK2, for sure.
But, with regard to the center 'diff/transfer case', it seems like if you had the keys to the computers, you could program a 'drift' mode that would lock it in RWD, and also lock the rear eLSD, and remove or dial the stability control system waaaaay down (lots of sports cars have this programming, with modes allowing more drift angle, etc by the driver).
Unfortunately, the software systems are now so secure that aftermarket tuners can't get into that system to add such a thing. Living at a ski resort in Wyoming, I would soooo love it if we could have a 'drift' mode, but as it stands, Jeep doesn't even allow traction control to be fully disabled, which is annoying for off road use as well. When the conditions are good, I just drive my old manual transmission Xterra with its fully defeatable traction control in 2wd with the electronic rear locker engaged (have to put it in 4 low to engage it, but if you shift back to RWD, it stays engaged :cool: ) for shits and giggles. As it is, though, the WL is a 'fun sponge' in the snow. If anyone ever offers a way to enable a 'drift mode' on the WL, I will be the first to buy it.
On the WK2, someone figured out that you could pull the center console cupholders up and install a 'kill switch' on the purple wire running up the tunnel and it would fully deactivate the ABS and stability control (once ABS is off line, the stability control can't operate either). Hopefully some resourceful person at least figures out how to do that on the WL at some point, and maybe there's a way to kill the wire to the center diff that would leave the front axle disconnected as well, if RWD is the 'default' mode.
As a car guy who likes manual transmissions and complete control over things, I'd really like those options.
I will be fully testing out the transfer case to see how it works, much like how I did with my WK2
My guess is the F05 fuse will make it RWD, but that may cause a bunch of other problems.
The transfer cases in jeeps don't require slippage to send power, lots of time it's just done by throttle input.
But since the Trackhawk had selectable modes with this transfer, its a matter if getting the parts and enabling them in the BCM and DTCM
I look forward to hearing what you find. I really want to find a way to completely defeat stability control, and would love to lock it in RWD too 😁. It would seem, like diffusing a bomb, if you can put a kill switch on certain wires (effectively cutting them), you could have a 'crude' version of what could otherwise be done with code. I'm sure it would trigger all manner of error codes and warnings, though, and could possibly require a dealer visit to reset in some cases.
To wit: my air suspension once defecated the mattress after towing snowmobiles, sending the rear sky high and the front to low rider setting after the trailer was detached, and I couldn't reset it. I had to drive it like that until the dealer could look at it and reset it. So, be prepared for things like that... but please try! 😜
Discussion Starter · #10 ·
I had something similar happen when towing.
I was hitching up my trailer (660lb tongue weight) and it never self levelled
My wife's look of "what did you break now"
I had to cycle the ignition a bunch of times before it fixed itself
Back to the RWD thing, I don't think HP tuners supports the WL but i'll see if i can read the TCM ect and see what's going on. Maybe getting a selec terrain trim piece with the buttons might be a fun project. I pick it up tomorrow so i'll start looking in to it then
Thanks for the info Sarge. Sounds like the transfer case tightens up (closer to locking) with 50:50 split in snow/mud/sand modes. I like that. (I’ll take anything I can get since I don’t have 4lo.)
Just curious, does front axle disconnect mean that the Jeep can be 4-wheel towed? Kinda doubt it but ask.
· Administrator
Do they still make the Trackhawk
No. It's gone. So is the "SRT". Any next generation "performance" Grand Cherokee, if one ever comes to be (I doubt it) will most likely be electrified just as Dodge is doing with their performance vehicles.
They have said they're 'considering it'. The SO Hurricane, when released, should be quite fast on its own. Based on my calculations, we could see a near 4.5 second 0-60 time from publications like car and driver.
There won't be another Hellcat or V8 performance model, but they could create a HO Hurricane GC, or possibly a SO and/or HO 4xe iteration as well, but I bet that won't come until the mid life refresh closer to 2028 MY based on interviews/statements from Jeep and this 'leaked' production schedule below (which looks consistent with Stellantis internal documents). A performance model would probably be for the 2 row, not the 3 row, but that's just a guess.
They're surely playing with test mules, but there haven't been any confirmations beyond 'it's possible' from Jeep directly (that I've seen). I'd be shocked if there weren't a group of engineers tasked with 'see what you can do', though.
Rectangle Font Parallel Screenshot Number
If everyone did their homework like you seemed to have done, perhaps there would be aftermarket tuners that would allow this. Unfortunately, almost nobody digs in as deep as you have. Have you ever tried asking anyone at the dealership a question about the 4-wheel drive systems in any of the Jeeps? They're stunningly clueless every time I've asked over the years.
The dealer seems only concerned with making their computers happy. Any further understanding of anything is superfluous knowledge from what I can tell.
As far as tuners go, though, it seems like the security imposed on the current gen of electronics is pretty strong, so the dev time to hack that is apparently vastly higher than it used to be. That being the case, it’s sort of a waiting game, and I’d guess we won’t see anything for our WLs unless the security can be hacked on a Wrangler and copy pasta’d to juxtapose it on the WL, Since the WL market is generally not spending a fraction of what Wrangler owners do on modifications.
Hell, almost two years in and a lot of us would be happy to modify our vehicles to perform as advertised.
Like many industries these days, workers are trained to do a task - follow a procedure. There is little return on investment to have people in these jobs trained above and beyond - it’s not the role. Just the reality of job in many industries today.
· Administrator
True, but I still doubt it. The overall market is moving in a different direction, including for high performance vehicles. If anything, I'd "bet" harder on a hybrid arrangement with the Hurricane over a pure ICE setup at this point.
Discussion Starter · #20 ·
Its not so much hacking, Unless the Jeep uses GPEC5 PCM HP Tuners has supported tuning jeeps for a long time. 2015+ have their PCMs locked but its easy, HP Tuners unlocks your original or you buy a used one and get it unlocked.
Security has already been "hacked" on Wranglers, just not one ones with GPEC5, so that would be some vehicles starting in 2021 (All 4xe's are GPEC5)
1 - 20 of 27 Posts
