This was discussed a bit at the beginning of April. Go to the following thread and take a look in the area of April 1, 2022. I much prefer having the QuadraDrive II with the eLSD.
Regardless of the language used, if there's no rear eLSD, the braking system is used for traction control for all tour wheels. The issue with dealership personnel is a whole 'nuther issue and has been that way at many dealers while not being a factor at others. You apparently got one that...
www.jeepgarage.org
Here's one of the comments I posted when it was asked whether 100% of the torque can be applied to one wheel without the eLSD.
john150 said:
I believe the ELSD can provide 100% torque to just one wheel. Can QTII do that or just to one axle?
On dry pavement I believe QuadraTrac-II can send all the torque to one wheel, but when wheels start slipping and brake traction control kicks in, you will be burning energy in your brake pads and rotors, thus leaving less than 100% torque available to be sent to any one wheel.
Here's the basic idea as I understand it.
QuadraDrive-II (WK2 and WL):
Brake lock differential in front, eLSD in the rear, and a transfer case that can send up to 100% of the torque to the front or rear axle.
If both front wheels are slipping, the transfer case will send 100% of the torque to the rear axle. If one of the rear wheels is slipping, then the eLSD sends up to 100% of the torque on the rear axle to one rear wheel that is not slipping. In this scenario, 100% of the torque can go to one rear wheel.
If both rear wheels are slipping, the transfer case will send 100% of the torque to the front axle. If one of the front wheels is slipping, then the brake lock differential (the brakes) kicks in to slow the front wheel that is slipping in order to transfer torque to the front wheel that is not slipping. This means even though the transfer case sent 100% of the torque to the front axle, if one of the front wheels is slipping, then some torque has to be "burned off" and lost to heat on that slipping wheel, which means less than 100% of the torque is available to the non slipping wheel. In this scenario, less than 100% torque will go to one front wheel.
QuadraTrac-II:
Brake lock differential in the front, brake lock differential in the rear, and a transfer case that can send up to 100% of the torque to the front or rear axle.
If both front wheels are slipping, the transfer case will send 100% of the torque to the rear axle. If one of the rear wheels is slipping, then the brake lock differential (the brakes) kicks in to slow the rear wheel that is slipping in order to transfer torque to the rear wheel that is not slipping. This means even though the transfer case sent 100% of the torque to the rear axle, if one of the rear wheels is slipping, then some torque has to be "burned off" and lost to heat on that slipping wheel, which means less than 100% of the torque is available to the non slipping wheel. In this scenario, less than 100% torque will go to one rear wheel.
If both rear wheels are slipping, the transfer case will send 100% of the torque to the front axle. If one of the front wheels is slipping, then the brake lock differential (the brakes) kicks in to slow the front wheel that is slipping in order to transfer torque to the front wheel that is not slipping. This means even though the transfer case sent 100% of the torque to the front axle, if one of the front wheels is slipping, then some torque has to be "burned off" and lost to heat on that slipping wheel, which means less than 100% of the torque is available to the non slipping wheel. In this scenario, less than 100% torque will to one front wheel.
