2014 Grand Cherokee 7" Screen Dead
49K views 27 replies 15 participants last post by  teaton1967
On the weekend I started up my 2014 Overland and went for a short drive to get a coffee. Everything was fine. After restarting my vehicle the 7" screen was dead. All surrounding gauges were also dead. Fuel showed empty etc...
I tried restarting the vehicle several times and nothing worked. I then tried operating my 8.4" touchscreen and while it was on nothing worked. It was on but the screen was unresponsive. I couldn't change the radio or access anything. I drove around for an hour and shut the vehicle off for 30 minutes. When I restarted everything was back to normal and it hasn't happened since then.
Has anyone else had similar issues? Did you have it checked out at the dealership?
I'm kinda worried now that I didn't take the extended warranty but my 2011 Overland was perfect. Never had an issue so thats why I declined the extended warranty on the 2014.
Any feedback would be greatly appreciated!
#5 ·
If the system does not detect the fault after several starts the light will go out, but the fault codes should still be stored.
OP - I'm not sure if it is the same for the '11, but we are being told that on the '14 the car does not completely shut down until the driver's door is opened and closed. Did you stay in the car with the door closed for those first few restarts?
One problem is not a reason to be worried about your extended Warranty choices. It could be a very small problem like grounding but your dealer needs to look at it as that is pretty major so I would expect a code was set. I personally watch a lot of threads on the radio, screens and HVAC controls. Haven't seen anything with this exact failure.
#8 ·
Dealership found a fault code for frozen screen however no corrective action was taken. It hasn't happened in the last week so I'm not going to worry about. At least they found the fault code and have it on record now.
Thanks to everyone for their feedback. I appreciate it.
#9 ·
We had the exact same problem in our '14 Overland this evening. Left the house and everything was working fine. Got back in the Jeep and dead screen and no control of the 8.4" screen. Restarted the vehicle three times and no luck on the screen. Truck is off for the evening, and will not know if it is working until some time tomorrow.
#13 ·
The vehicle not being completely off until after opening / closing the door is the difference. I did not know that fact. The 7" EVIC screen is operational today, although I had to restore my preferred user settings. Thanks all for the help.
#14 · (Edited)
Earlier this week with 820 miles on my Overland my air system started to give me over heating warnings in the highway. Took it in and they couldnt find anything. Then this evening my 7in dash screen goes out along with all tach, gas and temp gauges. Immediately contacted the dealership and dropped it off before they closed so they could personally see it - also got it on video. Ill post their findings...
http://youtu.be/0bsSw7UrAYA
#15 ·
2014 Jeep Grand Cherokee Overland Dash Dead - YouTube
Ugh. Odd that when the LCD is blank, the other "gauges" all show null. Wonder if it's a connection or something? Hope they figure it out quickly for you.
#18 ·
My 7" screen went dead yesterday. After shutting it down and letting it sit for 15 mins., the screen came back on. Used the vehicle a couple of times today and it worked fine. I didn't lose any personal settings when it went down yesterday. Akrenegade1, please post what your dealer discovers. Thanks.
#19 ·
Isn't it strange that these glitches seem to show up in clusters. There doesn't seem to be any correlation with build dates, mileage, etc.
I still think that Jeep, or uConnect, or maybe Sergio himself are doing stealth updates as they gather information for the next fix.
Or maybe I'm crazy. :D
Or both. :lol:
#20 ·
I hear ya Bill! Sometimes I think the Jeeps just like to screw with us to see if we're paying attention. :eek:
#21 ·
Although posted once before, while driving if you hold down the mute and tune buttons at the same time it will reset the Uconnect. I'm not sure if this would reset the 7" screen though. Might want to try this as it has had the same effect for the problems I've had.
Update: I've driven mine about 25 miles total since reseting to factory defaults and i havent had a problem... keeping fingers crossed.
Thanks all.
#23 ·
I have had the same situation with my 2014 Jeep Grand Cherokee Limited. I have 3,600 miles on it. I have had several instances where the screen goes dead or freezes and you cannot do anything. It has always reset after turning Jeep off. I finally took it to the dealer and they did a software update but on the way home it happened again. I am headed back to dealer on Wednesday. Its very frustrating. They said they may have to check the ground wire. Does anyone know if they have to take the dash apart to do this? I really hate to think they will....seems like once you do that you end up with rattles and noise.
#28 ·
Same story here. After the 2nd trip to dealer yesterday they are telling me they have to order a new radio and it will take about a week to get it in...so at least one more trip to the dealer. I am hopeful this will fix the problem and that will be the end of it.
It continues to go blank and freeze but works again after turning the vehicle off.
