Unlock passenger doors won't work
21K views 6 replies 4 participants last post by  Amelie
Hey maybe you all can help... So my unlock on the key fob only unlocks and locks the driver door. Same goes for both power lock switches on the inside. Don't know why nothing works and I'm worried I can't lock the lift gate or flipper glass now. Any ideas of why the rest of the locks aren't working?
#2 · (Edited)
There are some possible causes:
1) The passenger door module is faulty. But because the remote unlock transmitter
is mounted in the passenger door module, and the drivers side still works, i
wouldn´t expect this in the first place.
2) One of the lock motors is shorted, causing all the lock motors, driven by
passenger door module, to be inop. (so that are all, exept the drivers lock
motor). Also a shorted wire could be the problem. To find out if a lock motor is
the problem, you have to disconnect each motor electrically, one by one, and
check if the other motors start working again.
3) Both drivers side and passenger side door module share the same fuse, so that
can´t be the problem. But what also happens, is that on of the thick gauge
wires, who go from the door to the body through the rubber boot, breaks.
This normally happens more on the drivers side, due to the fact that this door is
used more often (for most of us at least:D), but could happen on the
passengers side as well. A look doesn´t cost anything (at least when it is your
look, a dealers look can be expensive:eek:).
By the way, for the time being at least, you could lock the liftgate manually. There is a small square plastic cover (5x5 cm approx) which hides a small manual lever, which allows you to lock/unlock the liftgate (and the flipglas together). It´s difficult to see the lever from what i remember, partly due to the isolation blanket which is in the way, but just feel with your finger.
No, in fact i swapped back to normal bulbs some 2 months ago after a low beam ballast burned out. Didn´t use the highbeam that much, so used that ballast for the low beams. Didn´t like the setup that much after all, because the HID bulbs have to heat up before they give enough light, so when signaling with highbeams, there was not that much light as i would have liked.
But now the highbeams are very yellow compared to the HIDs..................:(
