09 Wrangler Auto trans shift issues after lightning hit
29 views 1 reply 2 participants last post by  xJoshxx
im working on a 2009 wrangler automatic with 140k on the clock, vehicle took a lightning strike in June, at that time it was not capable of running, over the months it has had alot of parts installed some new some used each part was a positive move forward, Maks Tipm, Maks PCM, 4 new Tipm connectors, New WCM, used cluster, used multifunction switch, Used ABS module, new throttle body, new accel pedal assembly, new cam sensor, new crank sensor Now she runs and drives again, But my 1st to 2nd shift almost locks the rear wheels but only after each initial key cycle Hot or cold, installed new imput and output sensors and rear abs speed sensors and no change,
I now have a few codes 1- P0868, & U0259, I also tried to run a trans relearn 1st gear for a 42rfe and got an error message on 2 different scan tools { OBD empty response error }.
so im wondering if this is an internal electrical transmission issue or a bad tipm or pcm, all wiring and grounds have been inspected and repaired if needed already.
My next step was to drop the pan and replace the Valve body, the Soilinoind Package, trans pressure transducer sensor, trans variable force sensor and the manual valve lever sensor, new filter.
Didnt want to go throu that if the tipm is bad< i also ran a data stream on the trans, torque converter slip was 669 at idle and UD clutch fill volume was 41 at idle. This made me think i had good communication between the trans , tipm and pcm but im no pro.
Any and all input would be greatly appreciated Thanks
