2020 WK2 Upper Control Arms
1 reading
12K views 24 replies 9 participants last post by  SRTabc123
#1 · (Edited)
Does anyone know a place that sells 2020 WK2 upper control arms? JBA said they dont make them yet. Any help would be great. I bought the Rocky Road Outfitters 2.5 lift and want to do the UCA's at the same time as the lift. I wasn't aware that 2019 and 2020 UCA's are different.
#8 ·
UCA's for WK2 options as of this date
2011-2015 JBA & RRO
2016-and up only RRO JBA has them on their list to do but way down the list according to them.
Jeep changed the entire front end geometry in 2016 along with relocating the front swaybar to mount on a clevis attached to the front shock . Aluminum lower arms front and rear also. Not sure if this design is better or worse or what the benefits are. I owned a 2013 WK2 & now a 2017 , and the handling on & offroad is night and day. The new transmission and re- calibrated traction & 4x4 system is clearly eveident .
I've reached to several manufacturers regarding UCA's and they all have little or no interest.
#12 ·
I went with the Rocky Road Outfitters UCA's and had no problem with install and alignment ws spot on after lift and UCA install. View attachment 224085
Thank you for the pics update.
Researching a Air Suspension to coil conversion on a 2011. For a vehicle that will not be off road by my standards....
Wondering it the UCA's are worth the extra money on my older model.
