So I had a question I was looking at Matts write up about how to add a sub and amp to the factory stereo. That is an awesome write up but leaves me with a question. I am also wanting to add an aux input, the aux input I am looking at looks like it plugs in the same way as the aux output could I possible patch both in. Both come with a cable you plug in between the factory harness.
http://www.crutchfield.com/p_541CHYX/Peripheral-Auxiliary-Input-Adapter-for-Chrysler.html?tp=1672
thats that aux input adapter i want to use
and I was looking to use the
http://www.google.com/products/cata...bm=shop&cid=18092264330006830476&sa=X&ei=eaU8T8umBc2G0QGUlMDfBw&ved=0CCgQ8wIwAQ
PAC C2A-CHY3 for the rca outputs.
I guess what i was thinking is put both of the patch cables together? I think it is either that or splice one into the other which would probably be time consuming, but easy.
Not sure if this helps but this would be going in an 07 Grand Cherokee with the boston Acoustic stereo.
