Climate Control has a life of it own
1.5K views 4 replies 5 participants last post by  trekbuddy
Today I was driving with the AC on and it turned on both defrosters and won't move from 75 degrees or turn off the defrosters. I turned the truck off and then on and it does the same thing even after sitting for a few minutes. Any quick fixes for this? anyone encounter this, would rather not blow a Saturday taking it to the dealer.
#4 ·
Hi RPS256,
If you do decide to visit your dealership for any further diagnosis/repair, please don't hesitate to reach out if you need additional assistance.
Kori
Jeep Social Care Specialist
#5 ·
Did you hear any noises prior to them hanging up where they are? The complete electronic climate controls use up to 5 different blend doors with motors to get the HVAC combo you are setting it to. All of them can fail They use a plastic gear to run them that are notorious for failing. I just had to pull the entire dash out of a 2009 Dodge Ram because the one that failed was the one sandwiched between the HVAC blend box and the firewall inside the cab. Shitty design. Cheap plastic parts.
