Damaged Key Notice, No Convenience Keyless features will work, but...
1 reading
20K views 4 replies 5 participants last post by  jimmypapadopoulos71
I'm not sure about the rest of your issues but getting into the Fob is fairly simple. The easiest way I have found is to remove the emergency entry key from the Fob and use it to pry to two halves apart in the opposite corner. After that just pry it apart and snap it all back together when you are done. Hope this helps with your problem! :thumbsup:
